Why does WireCut split the top surface into two surfaces?
The original solid has one surface at the top:
The solid after cutting a notch has the top surface split in two parts:
WireCut.3dm (111.7 KB)
Interesting, using the gumball does not split the surface.
Here is another manifestation of the same issue:
  • Select the top face and drag it up with the gumball, and that top face does not split
  • Select the top face and drag it up with the PushPull, and that top face does split
PushPull.3dm (141.3 KB)
Even weirder!
Dragging the gumball does preserve the surface:
  • Create a rectangle on the top face of PushPull.3dm
  • Select the rectangle
  • Create a slot by dragging the gumball’s cut handle → the surface remains intact
Clicking the gumball and typing a number does not:
  • Create a slot by clicking on the the gumball’s cut handle and typing -6 → the surface is split in two
Gumball extrude just the surface also splits it. Also if there is no notch cut off.
The analysis mesh of the surface has an unwelded edge and an isocurve across what seems to be a crease has a kink.
How did you create the surface?
troublemaker.3dm (142.4 KB)
I don’t remember exactly.
It started as an extruded circular arc. Then I edited some of the surface control points, but I don’t remember the exact steps.
My guess is that, by moving those intermediate control points, I introduced a local G0 condition.
I understand that the surface is therefore not smooth there. What I don’t understand is why commands that do not touch that area at all, decide to split the surface into two faces at that location.
Actually it is fairly easy to introduce this kink.
I started with an arc, extruded it and pulled one of the control points of the surface.
A deformable arc would not help avoid the kink.
Many places in Rhino will split Brep faces along kinks when these faces are changed. We found that doing this generally reduces the number of invalid Breps, and improves the quality of the meshes created from the Brep. Many users have also said that when they insert a kink in a surface of a Brep, they wanted to have an edge there and so split the face in two.
You can use the CreaseSplitting command to disable that behavior.
I’ve made a YouTrack item to ask that the gumball cutter behave like that too: RH-99096 Gumball cut: Should listen to CreaseSplitting setting? I’m not sure this is the right answer here but the developer working on this will be able to tell us.
I didn’t know about the CreaseSplitting command. Thanks!
If they’re touching this, it would also be a good time to update the docs. PushPull isn’t in the list of affected commands, and the Gumball is affected too, although currently only in some cases.
Good catch, tracking here: RH-99099 CreaseSplitting doc: Update for commands affected by it
RH-99096 is fixed in Rhino 9 Service Release 1
