In using open nest v2, why does default option generate 100 copies of the same sheet?
The nesting works out fine though.
question about sheets.gh (18.3 KB)
My guess is, because you have grafted the Outlines input of the Geometry node.
Maybe try to flatten the OpenNest inputs.
I also wonder this? Sheets should be the number of sheets it used.
Also where did the spacing option parameter go?
Thatâs not affecting the output. Look at what param viewer is saying.
In new open nest v2, thatâs taken care of by âoffsetâ input of geometry.
Yes this always annoyed me. Not sure why there is a copies input at all⌠The component should automatically calculate how many sheets you need and output that.
Yes, I get that. It seems like a chicken-before-the-egg problem though. How would it know which geometry to take into account?
I donât think it isâŚYou input a single sheet perimeter. Then it tries to pack all pieces into it, when filled, it copies the sheet and so on until all pieces are nested.
This!! Exactly! Open Nest v1 used to precisely do this. There was no need to input the no. of sheets. It used to calculate the number of sheets required.
If we input â1â in the copies input, it doesnât automatically generate more number of sheets. I donât understand why would anyone want to input a number in here because leaving it blank makes open nest smartly calculate the requisite number of sheets perfectly.
