In the attached file I have frames that had been working for NetworkSrf. I got the file out after working on some other things and now they don’t quite work.
If I select all the frames and do NetworkSrf, it fails.
If do No Auto Sort, select the two vertical frames, shift, select the horiztontal frames in order, it works.
If do No Auto Sort, select the two vertical frames, shift, select the horiztontal frames in out of order, it fails.
I am curious why networksrf is not figuring this out on its own.
@scottd There is a separate curve there at the narrow end - - it looks to me like it ought to work.
It does, working up from the bottom, until you include the blue curve
I’ll get this on the list. My W. A. guess of the moment is that the sorter has trouble with the rail direction change, maybe…
