hello
due to the text flips when converting to dwg,
I wrote a script to fix text plane,it works when single textobj selected,
but if i select multiple text objects ,it failed.
I don’t know why, please help me, thanks.
import Rhino as rh
import scriptcontext
def FixTextPlane():
msg = "Select texts to justify text plane"
text_id = rs.GetObjects(msg,rs.filter.annotation)
if not text_id: return
if rs.IsText(text_id):
textpoint = rs.TextObjectPoint(text_id)
rs.TextObjectPlane(text_id,rs.WorldXYPlane())
rs.TextObjectPoint(text_id,textpoint)
else:
return
if name==“main”:
FixTextPlane()
The IsText()
method is failing because it is expecting a single object, and you are giving it a list (from GetObjects()
. If you have methods that accept only single objects and you want to apply them to multiple objects in a list, you need to use a loop.
def FixTextPlane():
text_ids = rs.GetObjects(msg,rs.filter.annotation)
if not text_ids: return
#this is your loop
for text_id in text_ids:
FixTextPlane()
BTW, if you want to post code in here, you can format it so that it looks correctly by enclosing it in 3 “backticks” like this:
thank you for solving!
Now I knew what the problem is and learned how to make it works, really thanks you!
