The annotated log below shows creating a cube and exploding it into six surfaces.
With SelAll → Join, Rhino joins the surfaces into one closed solid.
With Join → SelAll, it first selects the surfaces, then discards them and fails.
My question isn’t about how to accomplish the operation, it’s about understanding Rhino’s selection philosophy. I figured out the distinction after a few minutes, but it wasn’t intuitive to me: preselection accepts a selection, while postselection rejects the same selection.
Is this a consistent pattern across Rhino commands? Am I setting my expectations incorrectly when I expect preselection and postselection to behave alike?
create a cube Command: box
First corner of base ( Diagonal 3Point Vertical Center ): w0
Other corner of base or length ( 3Point ): w1,1
Height. Press Enter to use width ( BothSides=No ): w0,0,1
select it Command: sellast
1 extrusion added to selection.
Creating meshes... Press Esc to cancel
and explode it Command: explode
we have now 6 surfaces Exploded an extrusion into 6 surfaces.
Command: selnone
select them all Command: selall
6 surfaces added to selection.
run the join command Command: join
Surface join in progress... Press Esc to cancel
and we have a solid 6 surfaces or polysurfaces joined into one closed polysurface.
Command: selnone
Command: selall
this is the solid 1 polysurface added to selection.
go back to 6 surfaces Command: explode
Exploded a polysurface into 6 surfaces.
Command: selnone
run the join command first Command: join
then select all Select object for join. Curves, surfaces, polysurfaces, and SubDs must be open ( JoinDisjointMeshes=No SubDJoinedEdges=Smooth SubDSymmetry=Preserve ): selall
fails to create the solid Cannot use these objects. Removing them from selection.
Here is the macro used for this quick test:
;create a cube and explode it in 6 surfaces
box w0 w1,1 w0,0,1
sellast
explode
selnone
;join and select all -> it works
selall
join
selnone
selall
; -> 1 polysurface added to selection.
;join and select all -> it fails
explode
selnone
join
selall
