Why Does Clipboard Copy Slow Down with Many File Materials?
I have noticed this lately. If you try to make any cut or copy operation to clipboard from any geometry, even if the geometry has no materials and is not heavy, because the file does have a lot of materials, copying takes a lot of time.
Check this. I count 11 seconds to cut a newly created box. :melting_face:
Maybe this is silly or useless - however if I may ask: is this a downloaded ‘3D map model’? When dealing with downloaded/imported assets I’ve have to run this combo numerous times:
Check for bad objects, check for and delete duplicates, explode blocks (not always necessary), and purge.
Hi @ShynnSup,
CopyToClipboard is a file i/o operation - essentially export selected.
Most times, the venerable Copy command is a quicker option if you are not pasting into another .3dm file.
– Dale
Yes I am copying into another file.
It still does not explain why it takes 11 seconds to copy/export a single box. The size of the file or how many textures/materials it has should have no effect on this.
Is Export roughly as slow?
Thanks. The problem seems to be that Rhino sucks at dealing with materials. Even if you try to delete them all, Rhino will just crash trying to do so.
Just tried, not at all. It took less than a second.
Please post the necessary information to understand the issue. Thanks
Hi Japhy, this has been talked extensively, I believe no extra info is required.
I suspect the copy to clipboard issue has to do with materials as it often happens with files with a lot of materials.
I already took the time to record a video showing the issue. Also other people in this thread have corroborated it happens in their systems too.
Hi -
I’ve just read through those threads and other threads that were linked to from those, i.e, several hundreds of posts. Yes, this has been talked about extensively, but I couldn’t find one sample 3dm file that I can use to test this with…
Guys just to be clear, I don’t know what causes the clipboard copy/cut lag. It was just an intuition.
@wim I have just uploaded the file shown in my original post of this thread.
Hi Shynn -
Thanks. The file that you uploaded doesn’t include other objects than the box (other than a hidden block instance that only contains a single mesh face). Cut, Paste, and CopyToClipboard all are instant here. Could you check with that file that you uploaded instead of the one in the video? If that is equally slow, please also post the output from SystemInfo.
Hmm thats strange. I have the same lag on the uploaded file. Maybe it has to do with some plug-in after all?
Rhino 8 SR18 2025-4-10 (Rhino 8, 8.18.25100.11001, Git hash:master @ 5d157e876c23ece334d9c8666b8513ffc6d4a98d)
License type: Evaluation, build 2025-04-10
License details: Cloud Zoo
Expires on: 2025-07-19
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Computer platform: DESKTOP
  Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 4-12-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 576.02
OpenGL Settings
  Safe mode: Off
  GPU Tessellation is: On
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 4-12-2025
  Driver Version: 32.0.15.7602
  Z-Buffer depth: 24 bits
  Total Video Memory: 8 GB
  C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll	"Enscape.Rhino8.Plugin"	4.3.0.1186
  C:\Program Files\Rhino 8\Plug-ins\Commands.rhp	"Commands"	8.18.25100.11001
  C:\Program Files\Rhino 8\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	8.18.25100.11001
  C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	8.18.25100.11001
  C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp	"MeshCommands"	8.18.25100.11001
  C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	8.18.25100.11001
  C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	8.18.25100.11001
  C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp	"SectionTools"
@wim Any idea on what is going on? Thanks.
