Why can two Rhino installations share a .rui yet still look different?
I have two machines running Rhino which both load the same .rui off an iCloud Drive.
Yet, when I go to change a button on one machine and save the .rui, that does not reflect on the other machine.
Why is that?
It seems that when your first load the .rui you do get the contents from it on both machines, but any subsequent change after that is for some reason saved locally somewhere on each machine and each installation stops looking at the .rui they claim the options reference… well, except sometimes because when I used the V9 migration tool, that did mess up some commands in my V8 toolbars…
The RUI will save when Rhino closes. But in Rhino 8 it gest more complicated in that many changes will be stored in a Diff file. This Diff file is local file that saves only the changes to the RUI. So not all changes are saved in a RUI file itself.
Rhino 9 run differently, it will save everything in the RUI file. But may only save when Rhino is closed.
Sharing an RUI between Rhino 8 and Rhino 9 realtime will not work well. In fact saving a single RUi between two Rhino 8s can be a real challenge because of the diff files.
