Why can I not Boolean or Pushpull this solid extrusion?
I have tried in every way to make a shell of this ribbed circle. I have tried in Rhino8 and Rhino9 (Windows). While any command does not complain, the results are always a single solid disc, sometimes with a ghost-like wider surface on top. I want the walls 2mm thick (there is a curve in the drawing for this.
Ribbed Round Box v1 Rhino 8.3dm (614.3 KB)
Huh? Thanks, that works! Weird the other commands cannot do it.
