Why "await" doesnot work?
i wrote a component to do a long calculation work:
the function is :when input “true”,it output 0.516,when input “false”,it output 0.00
but you can see the picture above,the input is true,but the output is a tree data…and this output had to been shown by reconnect the component and panle.
this is the code:
 /// <summary>
    /// Registers all the input parameters for this component.
    /// </summary>
    protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
        pManager.AddBooleanParameter("B", "", "", GH_ParamAccess.item);
    /// <summary>
    /// Registers all the output parameters for this component.
    /// </summary>
    protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
        pManager.AddNumberParameter("N", "", "", GH_ParamAccess.item);
    /// <summary>
    /// This is the method that actually does the work.
    /// </summary>
    /// <param name="DA">The DA object is used to retrieve from inputs and store in outputs.</param>
    protected async override void SolveInstance(IGH_DataAccess DA)
        bool b = default;
        DA.GetData("B", ref b);
        if (b == true)
            double r = await GetLongtimeCaluculationAsync3();
            DA.SetData("N", r);
        else
            DA.SetData("N", 0f);
        //ExpireDownStreamObjects();
    Task<double> GetLongtimeCaluculationAsync3()
        Task<double> a = Task.Run(() =>
          GetLongtimeCaluculation()
        return a;
    double GetLongtimeCaluculation()
        double answer = 0;
        for (int j = 0; j < 10000; j++)
            for (int i = 0; i < 5000; i++)
                answer = Math.Sin(i) + Math.Cos(i);
            answer = Math.Sin(answer + 1) + Math.Cos(answer + 1);
        return answer;
thank you for help!
Hi Andrealu2012,
I am not an C#-Expert, but in your code you are accessing the paramoutput pManager via a string, not an index.
I am not sure, if this is possible, but you could try to use an index instead, like “DA.SetData(0, r)” and “DA.GetData(0, ref b )”
You could declare the variable “r” before you change it.
double r = 0;
if(b)
DA.SetData(0,r);
I hope it helps… I did not test it.
greetings,
Bumaye
