Are you using this?
https://marketplace.visualstudio.com/items?itemName=VisualStudioPlatformTeam.RoamingExtensionManager
– Dale
Thanks for the reply @dale,
No, I don’t think so. I have no recollection installing this. Unless it is part of VS2019 somehow.
I assumed Rhino and GH templates are simply not supported by VS2019 and got left in the limbo “roaming” until they are .
I don’t believe anyone (here) has installed VS2019.
You can still get VS2017…
I prefer not to downgrade, thanks.
I took one of my old startup projects (while I was with VS2017) and stripped it down to mimick a template. I’ll use that one, though I do not know what do I have to change between the projects. I assume the GUID but is that enough?
Yep, the assembly GUID for sure. The plug-in name and any command names too.
– Dale
Thanks Dale
