Why are Guides copied with data?
Hi, I’ve used a few guides recently in my R6 models and I couldnt work out why they appeared to transfer to other files (mostly ones that are part of the same worksession), even though I have removed them many times from the other files.
Now I have just realised what is happening; the guide seems to be copied to the other files when I copy/paste something from the file that has the guides.
Is there any way to stop this?
Thanks,
Jon
Hi Jon - thanks for the report, I’ll see if I can reproduce this.
I can… https://mcneel.myjetbrains.com/youtrack/issue/RH-46776
No problem… inadvertantly found a bug then :slight_smile:
