Hey guys, when I create an ‘interpolate points’ curve, the middle two control points are grayed/locked. If I insert a control point anywhere on the curve those two points will become active. In the past, these two points would be active the moment the curve was created, so I’m not sure if I changed a setting and am just having trouble remembering what needs to be adjusted.
Maybe you have the SubDFriendly option set to Yes in InterpCrv?
Well that was an easy fix. Thanks for the help!
