Why add crease is not working for naked edges?
Here’s a straight edge of a SubD surface:
I can also remove the crease:
But I cannot add it back using add crease.
Why?
you have to crease the point at the corner… there is nothing to crease on a naked edge because…it’s a naked edge. BUT you can crease a point which has access to 2 or more edges.
when you removed the creases, you actually removed the creases from the points, not the edge. It’s counter intuitive but that’s the way it works.
Try it via Vertics.
Yes, It works, thank you!
