Who uses SmartTrack
Are you aware of SmartTrack?
Do you use SmartTrack?
How frequently do you use it?
Do you usually work with SmartTrack on of off?
SmartTrack™ is a system of temporary reference lines and points that is drawn in the Rhino viewport using implicit relationships among various 3-D points, other geometry in space, and the coordinate axes’ directions.
Temporary infinite lines (tracking lines) and points (smart points) are available to object snaps very much like real lines and points. You can snap to intersections of the tracking lines, perpendiculars, and directly to smart points as well as intersections of tracking lines and real curves. The tracking lines and smart points are displayed for the duration of a command.
For more information see:
SmartTrack | Rhino 3-D modeling
I use SmartTrack sporatically when I really need to line things up geometrically, mostly in 2D views. It can also be helpful when choosing a start, intermediate, and/or end point that doesn’t land on a grid, snap point, or object’s OSnap (but still needs to align with other geometry). Using Tab is also helpful for locking in directions, and Between is also quite useful for midpoints between two points or OSnap options!
One thing we decided to do a few service releases back was turn SmartTrack OFF by default, since it can be confusing for new users. Powerful tool, though!
Coming from AutoCAD I’m very used to it.
Tons of temporary dots appear which makes it more cumbersome than AutoCAD’s. I sometimes switch it off for that reason but have it on most of the time.
And for me it’s a very good decison.
Still I don’t uderstand why Planar remains not the Default option.
@davidcockey I’m NOT fan of SmarTrack at all, but I’ve to admit that interior designer and architect nned it and love it.
I def. use smarttrack - but also had times when I fuc**d-up certain models by not being concentrated as, in tandem with snapping can get freaky.
In addition in heavy scenes it can start introducing massive slowdowns- which bother me most, I’d say
I use it occasionally, but I have tweaked the settings to limit the number of points to the smallest necessary, typically 3. I found the default settings could lead to a confusing propagation of points.
Have it turned on almost all the time, but turn it off/on quite often. Love the “single tap Ctrl to set, double-tap Ctrl to erase”-function.
-Jakob
I use it all the time - find its nice when building control-point-curves manually and laying down control-points with good tangency (mainly in 2D views, but the fact that it works well into perspective is awesome).
Am often working like this with grid-on, and the way that it overrides the grid constraints for these maneuvers is pretty handy.
off by default.
temporary on for some workflows.
started to use old school
.x
.y
.z
more often.
for all object-snaps - would love to see the final result (end, mid, int… and used smart-tracks) be visible for a few hundred millis…
I’ve learned to appreciate smart track now that ive been using solidworks it gives a similar approach.
Definitely underappreciated and a powerful function.
I use it for adding dimensions to 2d drawing
I use it quite a bit. Glad to have it.
Got used to similar feature in AutoCAD from 25 years ago. I seldom use SmartTrack, it’s off until I need it, then it’s good (not quite ACAD feel), and then off when it gets in the way again.
The “iffy” feel is maybe influenced by other OSnap settings?
I love SmartTrack - leave it on almost all of the time, always had people complaining about it when they’d come to look at something though, but together with One Shots, Elevator Mode and TAB I can usually place what I need with a lot less construction geometry - the automatic midpoint is exceptionally useful
It gets in the way once scenes get too detailed and can get a bit finicky when working in ghosted/XRay modes and the objects drawn behind it start to interfere, but then even that is useful sometimes
Always On, + guides (guides are awesome, they work well with SmartTrack, and they just need a little bit more love so they can exist dynamically and self-updating when placed along an object’s edge or related cases):
I use it very frequently.
I use it often and very rarely to do I turn it off. I really like the ability to hover over two points and it automatically creates a mid point between the two.
I hate creating help geometry or guid lines, therefore its on all the time, but yeah construction and interor here
not witout strg and double strg
I’m constantly turning it on and off. I have it set to the shortcut “STr” which I can just run mid-drawing when i need it.
What are “guides”? I’m not familiar!
