I try to generate a shape which responds to microclimatic constraints, I was advised to use " Discover" which turned out to be “a multi-objective solver” which is good. the problem is I have no idea how to use it
who among you has already experienced it?
Thank you.
up
Apparently not that many of us. I certainly haven’t.
I presume you are talking about this plugin:
Have you tried contacting the author using the contact email there?
I see he’s also here on discourse as @danilnagy
Sadly this plugin have poor support and 0 free explanation, you must pay to learn it.
This is a test, Galapagos find different result and faster than Discover, but discover work separately and support multiple objectives.
Discover need an option to get all result and choose between them
@anon39580149
First of all thank you !! I see a little light through your answer
can i know what you tested? I’m really interested
It’s a simple test to find scaled curve with defined area.
Discover find many results and sace them in a file but no option to import all results or find the folder,
because when the button clicked a new project folder created
I hope the developper answer and give more informations.
collide test.gh (14.4 KB)
@anon39580149 thank you for enlightening me
I will contact the developer as soon as I have gathered as much information as possible to make my questions more relevant
Thanks again for giving me hope !
