When I select the object in the layer named “Mesh Reduce”, I get a fatal error with white screen. I have to stop the program and relaunch. Happens every time. It first started when I tried to rotate the object, and then got worse.
Does not cause problems for me using Version 6 SR5 (6.5.18132.5131, 5/12/2018)
My guess is your experience is hardware related. Someone more knowledgeable about Rhino and hardware issues is needed.
Must be hardware. Tried on my other machine and no problem.
Hello - can you please run Help > System information and paste the results here?
Pascal, I’m running Windows on a late 2014 iMac…
OS Name Microsoft Windows 10 Pro
Version 10.0.17134 Build 17134
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name REX-PC
System Manufacturer Apple Inc.
System Model iMac15,1
System Type x64-based PC
System SKU Unsupported
Processor Intel® Core™ i7-4790K CPU @ 4.00GHz, 4001 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date Apple Inc. IM151.88Z.0207.B01.1411201235, 11/20/2014
SMBIOS Version 2.4
BIOS Mode Legacy
BaseBoard Manufacturer Apple Inc.
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Desktop
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume4
Locale United States
Hardware Abstraction Layer Version = "10.0.17134.1"
User Name Rex-PC\Rex
Time Zone Pacific Daylight Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.9 GB
Available Physical Memory 12.2 GB
Total Virtual Memory 31.9 GB
Available Virtual Memory 27.6 GB
Page File Space 16.0 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not InstantGo, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
