White lines in render view
Hello everyone,
My render viewport is displaying some thin withe lines on my subd. Converting to nurbs seems to solve the problem (not always) but it needs a few clicks… I don’t know if anyone has ever had this.
Thanks in advance
Hi Antoine -
Please run the Rhino SystemInfo command and copy-paste the output here.
Also, please post a simple 3dm file that demonstrates this behavior.
Thanks for the reply!
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15001, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Educational, build 2024-04-16
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 63Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4070 (NVidia) Memory: 12GB, Driver date: 10-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.03
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 1-11-2024 (M-D-Y).
> Accelerated graphics device with 5 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-15-2024
Driver Version: 32.0.15.6603
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.37.24107.15001
Making a “simple file” seems to get rid of the problem. I am assuming this is a performance issue ? I did a quick video on the file had a problem with. Moving the part also seems to get rid of it.
Not sure whats happening
does your material have a displacement channel?
it looks like the seams are tearing due to the displacement.
It would be useful if you could share the file you used in your recording.
Here is the file that is causing problems. I’m pretty sure it is because of the image textrure and maybe the uvs. I don’t know. Thanks your replies.
Issue_white_lines.3dm (16.6 MB)
Hi @Antoine_Jacquat ,
Try the command PackSubDFaces when you see this issue in Rhino 7. I had reported something similar four years ago (https://mcneel.myjetbrains.com/youtrack/issue/RH-62772) that could only be properly fixed in Rhino 8. That command helped in Rhino 7 though when this intermittent issue was seen.
With that said, I don’t see the white lines on your model here in Rhino 7.37 or 8.15 so it may be system dependent as well.
HI Brian,
That was was another good reason to upgrade to Rhino. It did indded fix the problem.
Cheers everyone.
