I’m unsuccessfully trying to render my model with a White Ground Plane. I set the reflection to 100% and in the render view it is perfect. But if I start the render command I always have a gray plane with shadows.
-Simon
-Simon
Just to check, where is your lighting? Is it above the ground plane?
I use ground planes less than McNeel might suspect, if they were inclined to do so.
Hi Brenda,
I have a reflector above the ground plane.
-Simon
In the plastic material settings scroll down until you see what in English is called Clarity
. That is by default at 85%. Rendered mode doesn’t show that ‘roughness’ so well, too sharp reflection. Bump it up to 95% or even 100% for better effect.
If you olok closely in your left render you’ll see that there is a reflection - the low clarity just doesn’t make it very obvious.
