When I import from SketchUp or from OBJ my geometry has white edges. Is there any way I can change that so the SketchUp object looks like other Rhino objects? Both objects in the attached JPG are on layer Default.
Might they be mesh objects that have a different edge display color than your surface objects? Or blocks that have curves concurrent with the edges? If you post a sample file someone can lookâŚ
That was it. I was only looking at the Layers panel. I put both objects on the same layer so I assumed Display would be the same. But selecting the objects and looking under Properties I see that Display Color is different.
Thanks for the guidance. I have a vast amount of SketchUp work stretching back over several years and I need to be able to bring it into Rhino when my ârepeat offendersâ clients call for revisions or new versions of old projects.
Of course, this will only be confusing with pure black and white object colors with the opposite as layer color⌠because Rhino, in its infinite wisdom, displays the surfaces of white objects as⌠gray, and the surfaces of pure black objects as⌠the same gray. With any other color combo, the difference of the object color from the layer color will most likely be more obviousâŚ
I wonder if I could jump in to this? I also have had problems with Sketchup imports for years. I usually work in Shade mode and when I bring in a Sketchup model it also has grey surfaces with white edges: See attached lamp png. What I want to do is have the lamps displayed the way a regular nurbs object would be: grey surfaces and black edges. I donât see how the display color makes any difference. I wonder if you would be kind enough to be more specific⌠step by step. How would we change it (if we can) to grey surfaces with black edges?
I suspect the object color is white and it has ended up on a black layer. Just select the object(s) and go to properties and set it to âby layerâ (if the layer is indeed black), or object color to black will also work no matter what color the layer⌠Does that work for you?
White and black surfaces are the same gray shaded, but surface edges and isocurves are layer color (unless you have changed that in a display mode - which is also possible in Windows.
I have attached the 3dm file for you to look at. The Sketchupâs properties are set to by Layer and the Layer itâs on is black. I even went to the Display settings for Shaded and changed the Mesh Edge Settings of the mesh objects so to âUse single color for all edgesâ and set the color to black and that didnât change it either.
Yes!! That did it â but why? Can anyone explain that to me? When I set the Display Color to âBy Layerâ itâs color (as you can see in the screen grab above) is white. Yet it immediately resolved the problem
Thank you.
Years of Sketchup import frustrations are now solved!
Thatâs interesting. If you look at the attached screen grab, you can see that my Display Color is set to âBy Layerâ is white-- and yet the edges have become black. Could this be a bug?
A minor comment - if the object in question is a block instance, the setting has to be changed in blockedit. I choose Trimmed Planes and make sure Display Color is set to By Layer for all geometry including blocks and I seem to be getting very clean geometry from my SketchUp files now that this minor issue has been cleared up.
For anyone who sees this thread laterâŚjCOMPONENTS (Blocks) that come from SKP files, need to be EXPLODED before the layer colors/line colors will be changed. Donât think anyone mentioned this yet in the thread
