Hi @siemen
Just script the ViewCaptureToFile command using rs.Command.
– Dale
RH-41282 is fixed in the latest WIP
I would like to see rhinoscriptsyntax functions for splitting and trimming surfaces using a curve (or curves) on the surface (instead of using a brep as is used in the SplitBrep() and TrimBrep() functions). The functions could be something like:
SplitSurfaceByCurve(surface_id, curve_id)
TrimSurfaceByCurve(surface_id, curve_id, point)
Where surface_id is the guid of the surface to be split/trimmed, curve_id is the guid (or list of guids) for the cutting curve(s), and point is a 3d point on the surface indicating which portion to delete during trimming. The SplitSurfaceByCurve function wouldn’t have to be much more than a wrapper around the RhinoCommon Brep.Split method, but would hopefully be easier to use for those who aren’t as familiar with RhinoCommon.
Reported: RH-41493
Late to the party here, but @piac I do not see rs.IsExtrusion anywhere… Thx, --Mitch
Thanks, reported: RH-43346.
Adding to the list:
rs.ObjectTopGroup()
rs.DimStyleScale()
Thx, --Mitch
Hi Giulio,
rs.SaveSettings()
Also please have a look at this:
I am no longer in charge of this, but I reported these:
https://mcneel.myjetbrains.com/youtrack/issue/RH-49189
https://mcneel.myjetbrains.com/youtrack/issue/RH-49190
https://mcneel.myjetbrains.com/youtrack/issue/RH-49191
Thanks,
Giulio
Giulio Piacentino
for Robert McNeel & Associates
giulio@mcneel.com
Bump on rs.ObjectTopGroup…
Hi Mitch, Fyi, I added the function and some notes to the YT item
Thanks @Alain ! (I understand the limitations of this function, yes…)
