Which plug-in can I design the "Emergent form" with the Grasshopper?
Hi !!
I want to create different forms by defining volumes in the same function using Grasshopper. I have keywords like herd behavior, emerging systems, ant behaviors, agent-based models. Which plugin can I do with a work like the following example?
Hi Senakurkcuoglu,
there are a lot of examples here in the forums, and in the internet.
You could check Culebra to understand how agent systems works.
another plugin to get permutations from one system would be Biomorpher, which is a great solver to get different combinations of forms and so on.
There are a lot of possibilities.
greetings,
Bumaye
hi,you have keywords which is a good thing. u can search food for rhino
using keyword it will filter the plugins for you.
