I found this method: https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Display_RhinoViewport_GetWorldToScreenScale.htm
I wonder which event is triggered upon the change of its value?
One way is to create a display conduit and override Rhino.Display.DisplayConduit.CalculateBoundingBox
, as this will be called when zooming.
– Dale
Hi @dale,
CalculateBoundingBox seems to be firing not only during zoom but also pan. Is there a way to isolate and trigger only if zooming?
Sorry, no.
– Dale
I wanted to GetWorldToScreenScale within the event handler but Rhino crashes.
This is what I do:
If you uncomment either of the commented lines rhino will crash.
import scriptcontext as sc
import Rhino
vp = None
class dc(Rhino.Display.DisplayConduit):
def CalculateBoundingBox(self,e):
global vp
vp = e.Viewport#.GetWorldToScreenScale(pt)[1]
print vp#.GetWorldToScreenScale(pt)[1]
def zoom_event_helper_func():
#Event trigger helper function
if sc.sticky.has_key('ZoomCallback'):
callback = sc.sticky['ZoomCallback']
if callback:
callback.Enabled = False
callback = None
sc.sticky.Remove('ZoomCallback')
print "zoom event listener stopped."
else:
callback = dc()
callback.Enabled = True
sc.sticky['ZoomCallback'] = callback
print "zoom event listener started."
Can you think of any workaround, @dale?
Update:
Oh, now I see pt is not defined.
Heeyy I got it.
