Is it special class or simply GH_Component with custom attributes?
Here as far as I understand ghpython is derived from a special type. Is there something special for sliders too?
Thanks in advance
Thanks in advance
That said, I would like to put things in order and leave the other thread for Galapagos. This one for Slider alteration.
Hi @DavidRutten,
I have a couple of questions about the GH_NumberSlider:
are the methods/attributes/properties inside it all public?
Although since they don’t show in the autocomplete I think I have my answer.
what are the names of the min and max values properties/methods?
The domain, value, etc. are properties of GH_NumberSlider.Slider. E.g. you can set GH_NumberSlider.Slider.Min and GH_NumberSlider.Slider.Max. If the current value of the slider is not inside the domain this will create funny graphic effects
I think there were large posts regarding slider manipulation in the past, search the forum for GH_NumberSlider and you will find immediately.
Could you share how did you find these?
This shows up in my autocomplete… But I think GH_NumberSlider.Slider is a handle to GH_SliderBase which should be documented.
https://developer.rhino3d.com/api/grasshopper/html/T_Grasshopper_GUI_Base_GH_SliderBase.htm
Unfortunately, if I create a class derived from GH_SliderBase
it will not be exactly like extending GH_NumberSlider
, which ultimately will cause Galapagos to reject it.
That’s part of another discussion, I think
Anyways, I was not suggesting to derive anything from GH_SliderBase. All I was saying is, that the properties you seem to be interested in (slider value, min value, max value, type etc.) are not properties of GH_NumberSlider, instead GH_NumberSlider carries an instance of GH_SliderBase which exposes the beforementioned properties. If you want to manipulate a slider, you can do so by getting a handle to a slider object on the canvas (which will be of type GH_NumberSlider) and access it’s Slider property.
