Which commands to use to model this
I need to model this object and was wondering which commands to use to do it. I would like to not use grasshopper and think it’s possible. The issue is filleting the edges to make it look like the fabric on it. I’ve been trying sweep 1 and 2 but it’s not getting to look exactly like it. I have rhino 7
without grasshopper and kangaroo it might be even more a fiddle… but if the quality is not extremely important then you can use patch to create the surfaces.
for this overbuild the edges on each side. turn on history before patch and use additional points in mid air to adjust the patch if needed. it also work without but it gives you a better control. to close up the edges you might have to set the patch to a high resolution and maybe use blend edge, but i leave that to you.
I would try to start:
  1. Planarsrf for top and bottom.
  2. Loft front and back
  3. Loft sides
