Create a splashscreen then call it On_Load plugin:
Dim splash As New SplashScreen1
splash.Show()
splash.Enabled = False
then in the splash screen On_Load me.hide
and put:
Private Const WM_DEVICECHANGE As Integer = &H219
Private Const DBT_DEVICEARRIVAL As Integer = 32768
Private Const DBT_DEVICEREMOVECOMPLETE As Integer = 32772
Protected Overrides Sub WndProc(ByRef m As System.Windows.Forms.Message)
MyBase.WndProc(m)
If m.Msg = WM_DEVICECHANGE Then
MsgBox("")
End If
End Sub
In general, these types of “things” are handled in a message-only window. This can be a form that is invisible or a class that inherits from NativeWindow.
Oke. I got a invisible form now but I think a NativeWindow is better.
I found this:
' NativeWindow class to listen to operating system messages.
Friend Class MyNativeWindowListener
Inherits NativeWindow
' Constant value was found in the "windows.h" header file.
Private Const WM_ACTIVATEAPP As Integer = &H1C
Private parent As Form1
Public Sub New(ByVal parent As Form1)
AddHandler parent.HandleCreated, AddressOf Me.OnHandleCreated
AddHandler parent.HandleDestroyed, AddressOf Me.OnHandleDestroyed
Me.parent = parent
End Sub
' Listen for the control's window creation and hook into it.
Private Sub OnHandleCreated(ByVal sender As Object, ByVal e As EventArgs)
' Window is now created, assign handle to NativeWindow.
AssignHandle(CType(sender, Form).Handle)
End Sub
Private Sub OnHandleDestroyed(ByVal sender As Object, ByVal e As EventArgs)
' Window was destroyed, release hook.
ReleaseHandle()
End Sub
<System.Security.Permissions.PermissionSetAttribute(System.Security.Permissions.SecurityAction.Demand, Name:="FullTrust")> _
Protected Overrides Sub WndProc(ByRef m As Message)
' Listen for operating system messages
Select Case (m.Msg)
Case WM_ACTIVATEAPP
' Notify the form that this message was received.
' Application is activated or deactivated,
' based upon the WParam parameter.
parent.ApplicationActivated(m.WParam.ToInt32() <> 0)
End Select
MyBase.WndProc(m)
End Sub
End Class
Do I just put it under the Plugin Class or do I need to call it somewhere?
Since I don’t really know what you are doing, I’m not sure what to tell you. But you might consider storing one of these on your plug-in object. Then, create it when your plug-in loads and destroy it when you plug-in unloads…
I have a security file so my plugin will work when the usb is connected. Too prevent people from removing the usb and putting it in another pc so they can use the software mulitple times. I want to keep track if they remove the usb. Thats why I need the WndProc.
I’ll try when I got the time
Doesn’t a plugin not only unloads when rhino is exited? And when Rhino Exits the plugin will be “disposed”? So there is no need to destroy it?
