I have tried to make the simplest of scripts that would make a subcurve as long as another curve. Main issue is that I can´t find any SubCrv method. Tried working around it with rs.Command to basically macro the thing but this is somewhat cumbersome to work with further.
So what actually is the _SubCrv and how else than with the rs.Command can it be used in a python script?
It’s basically like substring, you only take part of the curve, usually defined by two parameters t0 and t1, which represent start and end of the subcurve.
