Where is the structure windows in rhino?
I am starting to be familiar with Rhino7 and don’t find a structure window that includes solids, surfaces, and curves.
Would you please advise where is the window “structure” includes the parts of the drawing?
Hi IOANNIAS,
Can you elaborate on what you mean by Window? are you talking Door - Window or the computer OS Windows?
Rhino doesn’t have a ‘feature tree’ like I think you’re asking about. Rhino models are largely ‘flat,’ it wouldn’t do much for you, it would be…here’s everything!
Thanks
Window say a part of screen with structure tree includes solids, surface and curves as in catia and space claim.
The jim answer is clear there is not.
How I can select e.g. solid 5 add to solid 6 only by the mouse?
To merge two solids you can use booleanunion from the “solid” tab, and it will merge them.
Rather than selecting from a tree, you select the objects directly in 3d model.
The transition from Catia can be somewhat tough, however you will find Rhino is much easier.
