Where is the Closed Crv Seam Located with Curve.CreateControlPointCurve?
I know the seam changes given the degree, but how? I’m trying to match the functionality of __CurveThroughPolyline, where the seam always matches the seam of the input polyline.
Curve.CreateControlPointCurve puts the seam on the pts[0] location for deg1, but I can’t figure out how subsequent ones are calculated.
Hi @EricM,
The seam of a closed NURBS curve can be found at NurbsCurve.Domain.Min.
The domain of a NURBS curve is determined from the curve’s order, knot vector, and control point count.
– Dale
Could you share the source for how _CurveThroughPolyline turns a poly into a crv? That’s essentially what I’m doing, but that function isn’t in RhinoCommon.
_CurveThroughPolyline always makes the output curve’s seam at (or a half step from) the input poly’s seam.
The CurveThroughPolyline can create a curve in a number of ways depending on the command line options select.
How do you use this command?
– Dale
someClosedPolyline →
_CurveThroughPolyline pause CurveType=ControlPoint Degree=5 DeleteInput=No
Hi @EricM,
That should be the equivalent of:
var rc = NurbCurve.CreateControlPointCurve(points, 5);
– Dale
Visually they are identical, but the seam moves when you specify periodic=yes.
So _CurveThroughPolyline’s source isn’t public somewhere? If not I guess I’ll start googling periodic curves to see how cps should be duplicated.
@EricM - here is the underlying magic:
ON_NurbsCurve::CreatePeriodicUniformNurbs
– Dale
I was really hoping for this source:
public class CurveThroughPolyline: Command
    public override string EnglishName => "CurveThroughPolyline";
It’s re-ordering the input points somehow.
If I understand the cpp correctly, the multiplicity of the points is specified here:
for (i = 0; i <= order-2; i++)
      SetCV( m_cv_count-m_order+1+i, ON::intrinsic_point_style, CV(I) );
And order means span length, aka degree + 1, so it’s duplicating degree - 1 points? When I look at my output curve, it follows that pattern, but my question is, where is the seam? Does it fall on (degree - 1) / 2?
Hi @EricM,
The CurveThroughPolyline command is written in C++.
As I have already mentioned, the seam of a closed NURBS curve can be found at NurbsCurve.Domain.Min.
If you want/need to move the seam, use Curve.ChangeClosedCurveSeam.
– Dale
