Where is document settings? in V6 & V7?
In version 5 i would right click the blue ball to get document properties… can I please ask the shortcut now in v6/7
at the moment i have to type Document Properties…
silly question I am sure to some but these little things!
File menu > Properties or Tools menu > Options… or Standard toolbar > Sprocket icon
Regards
Jeremy
thank you!
i never realy have or take the time to go through all new options/changes… client deadlines prevent this… so I just end up in V5 as I can work fast with workflow i have used for years
This is not new… DocumentProperties and Options have been together under the ‘sprocket’ button since like V1.1 or V2…
sure BUT in v5 i could right click the blue ball icon (render) and they would come up… changed in 6/7 hence my question
Yes - in V5 the macro for the RMB on the ‘blue ball’ button was:
! _DocumentPropertiesPage
_Render
In V6 it was changed to
! _-Rendering _ShowPanel _Toggle _Enter
I guess because the render settings were added as a panel in V6.
You can of course change your macro back to the V5 one if you want.
thank you - please can you remind how to do this?
With only one instance of Rhino open:
  • Shift+right click on the button to open the editor.
  • Replace the V6/V7 macro with the V5 macro above and OK to confirm.
  • To be sure, go to Options>Toolbars and from the File menu, choose SaveAll.
thank you - works perfect
