Hi, I hope someone can help me, I’m using the lastest beta of Rhino with Mac OS X Yosemite beta 4. When I try to draw a line, curve, anything, to the right you can see the command line, but when you try to put a point of start or the dimension of the line, there’s no more command line so I can’t do draw anything with precision I can draw it just with the mouse. There is a kind ok option that I can activate in order to make visible this command line?
The command options in the sidebar does not work in OS X Yosemite. As a workaround, in Rhinoceros > Preferences > Themes, select the Custom theme in the drop down menu and select the “Use command options dialog” radio button.
