Where can I find “Add wall(Curve)” in Grasshopper while using Rhinoinsiderevit?
This is the system version that I use:
Rhino 7, 7.11.21293.09001
RhinoInside.Revit_1.5.8101.24584
Could help me with this one, I’d be glad. Thank you.
Simply type in Add Wall. Or go to Revit tab, under Build. Add Wall by curve is there.
Assuming you are opening Rhino within Revit.
Somehow, It is not under the Build
tab, but I was able to find the answer by typing it. Thank you.
Then it must be under the Wall section.
