Hi
Found out there were 120 copies of the same material
No idea how they multiplied so successfully inside this early draft/wip model
Thanks a lot
Akash
Hi
Thanks a lot
Akash
Hi -
Could you please post your SystemInfo
output and steps to reproduce this behavior?
Hi Wim
bellow is the system info:
As far as steps to reproduce this… well I have no idea
it happened in a file that had an older file [probably v5] imported into it at one stage, the 24k material infection may have something to do with that.
unfortunately by now I deleted all these duplicate materials as the material panel became unusable.
But for sure. after importing the older geometry, I didn’t have these duplicates yet. so that must have happened at some point later on in V7.
I understand it’s likely not reproducible issue…
Thanks a lot
Akash
System info>
Rhino 7 SR0 2020-6-16 (Public Build, 7.0.20168.12016, Git hash:master @ 7bf116d4a070e798e12ca7eb8198e9de6c0987f0)
License type: Commercial, build 2020-06-16
License details: Cloud Zoo
Expires on: 2020-07-31
Apple Intel 64-bit macOS Version 10.15.5 (Build 19F101) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro11,3
Language: en-IL (MacOS default)
NVIDIA GeForce GT 750M OpenGL Engine (OpenGL ver:4.1 NVIDIA-14.0.32 355.11.11.10.10.143)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 2 GB
Graphics: NVIDIA GeForce GT 750M
Displays: Color LCD (221dpi 2x)
Graphics processors
Intel Iris Pro (1536 MB)
NVIDIA GeForce GT 750M (2 GB)
Color LCD (1440 x 900)
USB devices
Apple: Internal Memory Card Reader
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
3Dconnexion: SpaceNavigator for Notebooks
Wacom Co.,Ltd.: Wacom Intuos Pro M
Bluetooth devices
Apple: Apple Magic Mouse
Third party kernel extensions
com.3dconnexion.driver (1.1.0) 94E8C49C-EDED-3526-88BE-E7207560C0D2
com.sophos.nke.swi (9.9.4) 1A584D27-3B41-3F92-9D0D-8A30EA3E50F8
com.sophos.kext.oas (9.9.4) 7CED455E-0A13-323E-B39B-FAE664394522
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftFoundation.dylib
/Users/akash/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/bella_rhino.rhp/libbella_dotnet_native.dylib
/Users/akash/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/bella_rhino.rhp “Bella” 20.7.0.0
/Users/akash/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Iris.MacR5.rhp “Iris” 1.0.0.0
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.0.20168.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.0.20168.1002
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.0.20168.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.0.20168.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.0.20168.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.0.20168.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshUtilities.rhp “MeshUtilities” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.0.20168.12016
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.0.20168.12016
Hi Akash, I see Bella in there, and though I do not believe there is any code in it that could be involved in producing this behavior, if you could send me a simplified file that produces the behavior, I’d like to check it to be sure.
Hi
Certainly if it happens again I’ll make sure to send you the file.
At the moment I have no idea where this come from so I can’t intentionally recreate it.
Thanks a lot.
Akash
