When multiple sessions open, all but one freezes
OK, I have a consistent problem that has persisted through the last update. I often run with multiple sessions of Rhino open as I use components of prior projects in new projects. Copy and paste works great. Since Rhino 8 when I’m working with two or more sessions open, the non active sessions freeze at some point. Can’t close them, can’t work with them, can’t copy and paste. I end up using task manager to close them down. Fortunately, since I’m just using those sessions to copy from, I don’t usually lose work. But this is a problem I’d like to see resolved as a higher priority.
Rhino 8 SR7 2024-5-17 (Rhino 8, 8.7.24138.15431, Git hash:master @ 03702f889bdef32626af4bca510b5e8a85666d38)
License type: Educational, build 2024-05-17
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.19
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 10-19-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 545.92
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-19-2023
Driver Version: 31.0.15.4592
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.7.24138.15431
Hi Gary -
I don’t recall other reports of this behavior which points to something machine-specific.
Please start by updating the drivers for the GPU.
Make sure to pick the “Clean Install” option when installing new drivers.
Wim, I did the driver upgrade and was thinking it had resolved the problem, but then today it happened again. The idle project was frozen when I went to shut down Rhino for the time being.
G
Hi Gary -
When one of the Rhino instances freezes, please follow these instructions to create a memory dump file and send that in → Manually Creating a Memory Dump (DMP File) from an Unresponsive Rhino for Windows [McNeel Wiki]
