When I run my code on another computer, I get errors
hi everyone
I have a problem with my Karamba algorithm. When I run it on my computer, everything is fine. But when I run it on another computer, I get errors like the images below. How can I fix it?
best,
elif
Hi, one suggestion is to remove the pt input in the assemblemodel component. You only need this if you need to organise your pts in a specific order for zero length elements.
Also, you can check the unit settings to see if you are working with the same tolerances in Rhino.
best,
Matthew
