grivna.3dm (9.4 MB)
Hi @maimun2002
Iām guessing, that you are referring to the two small, open surfaces near 0,0,0? My guess is, that youāve made the surfaces using the nearby curves(NetworkSrf
?) and then mirrored and scaled. If thatās the case, try making the surface from the curves, mirror it and join the two halves (which should work) and THEN scale. When you scale before you join, the edge is āscaled out of toleranceā, so to speak, and if you zoom in on the edges of your current two halves, youāll see that the edges are actually not overlapping. The tolerance in NetworkSrf
is determined by its dialogbox, and if you modify your geometry afterwards, you can easily get things out of tolerance. By joining BEFORE you scale, you let Rhino know, that those two edges need to āstick togetherā.
HTH, Jakob
Actually, if you just scale your existing two halves on the X-axis, they join just fine, and you can then āre-scaleā them to the desired width.
-Jakob
Even if I donāt scale, when i join and merge all edges on the mirrored polysurfaces it still creates an open polysurface.
Hi @maimun2002
I just checked to see, if maybe it was a "Rhino5 vs Rhino6 "-thing, but Iām getting the same result in Rhino5 - see attached video. If I join the two halve before scaling, thereās a naked edge spanning half the shape. If I scale the width to 0.5 and join, it becomes a closed polysurface - and stays closed as I scale the width back up to the original width (by factor 2). You are not seeing this?
-Jakob
Hi, sorry Iām still new to the program
watching the video i saw you typing āāiccāā in the command tab witch selected only the edge, i tryied typing the thing but it says that there is no such command.
Sorry @maimun2002 - just one of my aliases. It turns off the isocurves of the surfaces. Itās not important for the the rest of the video or the functionality of the rest of the commands. I just prefer my surfaces without all the isocurves (the thin black lines on the surface). Itās purely cosmetic! Itās just the -Properties Object ShowIsoCurves No
on a button. You can get the same thing by going to the properties tab (with an object selected) and remove the tick from āShow surface isocurvesā (Under āIsocurve Densityā).
-Jakob
Oh God hahaah I got it, it is way simpler than i thought , Thanks a lot!
Cheers!
