When Clustering create outputs automatically
When we cluster in Grasshopper, it would be nice if it created automatic outputs from parameters, just like it does for inputs.
If I have this:
Then I select everything inside the purple group and cluster we get:
How come its not adding the output as well? Seems like a bug to me. Thanks for fixing!
This is in Rhino 8.32.26160
By such logic you would get also outputs from your evaluate surface component
Point
Surface
U direction
V direction
Frame
Stupid, no? Your input gets cluster input because it is connected elsewhere in the script. Same logic applies to outputs, its not a bug
Ah, of course. In a momentary lapse of reason, I falsely assumed its connecting the parameters, but of course you are right that its connecting the inputs and it didn’t create an output, because I didn’t have it connected.
I always use named parameters everywhere in my script, so I should have created another parameter and then selected everything except the last parameter, so that it has an outbound connection.
Of course it shouldn’t automatically create an output for each output of a node, I am not that dumb..
