I want a consistent mesh for these two shapes, whereas now I have two independent meshes.
Any advice welcome.
breps.gh (40.3 KB)
Thanks
Any advice welcome.
breps.gh (40.3 KB)
Thanks
Try to use Brep join comand to join both breps and then use Triremesh comand to make a mesh from both joined breps.
Regards!
Couldn’t [brep] join them, seemed to be the problem!
Thanks
It isn’t possible because the brep and the surface don’t share naked edges where they meet.
What’s the solution here? How to I build these surfaces so that they can be meshed together?
Thanks!
Did you try to split a brep with the other brep then join?
Indeed, I did. Maybe here the issue is caused by three surfaces intersecting at a single edge, i.e., a non-manifold edge?
In my opinion, your goal of getting one “consistent mesh” from this brep and surface is pointless, because it would be an invalid mesh with non-manifold edges. Meshes are meant to be either surfaces or solids.
The highlighted, orange edges are non-manifold in the example above, which is super bad news.
What would be possible is to reconstruct the two n.u.r.b.s objects as two distinct meshes with matching topologies.
Hi @James_Whiteley,
you can try NonmanifoldMerge but be aware that it causes many commands to fail as it is not clear where the inside and outside is.
_
c.
It will come back to bite him in the ass later.
Absolutely. That’s why i linked to the helpdoc which also gives that information.
it seems the mesher does not complain and does what the user asks for.
_
c.
@clement thanks for the advice, I will give it a try.
@diff-arch the goal is FEA, similar to analysis of a stiffened cylinder, hence the geometry. I wonder how others managed it, e.g., in the image below.
