I would like to take a solid made up of mesh surfaces and translate it into a number of shapes that roughly represent the origin shape. I have attached a quick simplified sketch to explain. I feel I have seen this done before. I would like to separate the solid into layers of 2.5mm thickness material. Thanks in advance.
Use the command Contour to create the 2.5mm slices as curves, then extrude the curves (all at once) 2.5mm.
That is absolutely perfect. Works a treat. Thanks so much
