What to do with jagged squares rendering Flamingo nXt
When I create complicated models in Rhino, I get strange jagged squares in my renderings. Especially glass reflections.
Please see attached images
Does anybody now how to fix this problem?
Hi Rick,
I think that is due to the HDR used in the sky. It is pretty low res and the jaggies are the actual pixels of it being reflected. You can either use a higher resolution HDR in the sky or blur a low res one externally. An alternate approach is to decrease the sharpness of the material to scuff it up slightly. In the case of a glass material, this might make it too frosted looking. Here’s an HDR I made that is already blurred to test with.
Blur_Loft_sm.zip (1.0 MB)
Hi Brian,
Thank you very much. I will use your hIghtes HDR file. That’s a bIg help
Met vriendelijke groet,
Rick
ir. Rick Porcelijn
16 Mammals - executing commercial product ideas
mobiel 06 481 727 14
telefoon 020 89 323 69
web www.16Mammals.com
KvK 56312938
Wil je zien wat mij inspireert, bekijk dan mijn images en infographics verzameling op www.pinterest.com/porcelijn
Verstuurd vanaf mijn iPhone
Hi Brian,
Adjusted the resolution and blurred the HDR image. Way bettter!
Thanks a lot
Rick
ir. Rick Porcelijn
KvK 56312938
Wil je zien wat mij inspireert, bekijk dan mijn images en infographics verzameling op www.pinterest.com/porcelijn of schrijf je in op mijn nieuwsbrief
