I get this mesh to be projected on the circle curve extrusion. If i do not provide anything to the U,V,W, components showes an error
surface morph.gh (16.4 KB)
It shouldn’t be pulled on surface, I am generating height variables in xy plane to translate them onto curved surface
Hi @Urchuck!,
That’s a weird Sporph you were using—where did it come from?
surface morph.gh (49.6 KB)
You can sporph the mesh too I guess, but often points is faster ![]()
You could try other things like MeshMap or ShapeMap (Rhino WIP) but simple sporphin’ should do.
Does this look correct? I went back to an earlier point in your script to illustrate the method.
The seam will continue to be an issue unless you make the mesh on the surface itself, I believe, rather than making it flat and then mapping it back.
I guess, to control that seam, you’d need a different base surface, similar to this:
surface morph2.gh (50.4 KB)
I skipped Delaunay triangulation and went for TriRemesh instead.
Ignore this, you were using surface wrap I think.
Here’s an example of a seamless pattern:
As you can see I arrayed a point set three times. This let’s you pick a segment…
