V5 racing against clock , skip lunch, and probably eve meal as well !! …and in wireframe I am overwhelmed by crosses when all I want are the brick outlines.
No time to explore a fix so asking for a qiuick fix, what setting to turn off and what on to get outlines only in wireframe mode of solid object bricks ?
How about at least a screenshot sho we know what “crosses” mean to you?
If you’re talking about surface isocurves, you can either disable their display in the Shaded display settings, or make a copy of Shaded and tweak those settings.
I imagined the display would have a turn off , rather than the object itself. If I create another brick it will have crosses on all faces ? until I select it and go to object properties, and as I am forever making bricks is there a way of doing this once only and anything such as bricks dont display with crosses on all 6 surfaces ?
in wireframe I untick as per your screen grab, show isocurves, I select a brick and there are crosses an their faces. I am staring at a myriad of lines with bricks selected, just wish to see yellow selection colour on their edges.
ditto shaded mode.
just unable to get this job done, no breakfast at this rate
Steve
Then you need to turn it off both at the level of the object and the display mode.
Note that why you’re so upset over this display attribute is baffling. Also, everyone trying to help you has work to do too, no one cares how behind-the-8-ball you are, other than finding it confusing and slightly concerning how you keep getting into these messes.
at the level of the object, so as initially said select the object and turn it off in properties.
But what if I create another brick ?
I am working with many bricks and cannot see what I am doing with every brick having 6 crosses , its a massive sea of crosses, I am against clock and last thing I expected was to struggle with a sea of crosses. set me back another hour now the last thing I wanted. I myself care if I have an eve meal at 3am ! I dont expect others to care, and I never said anything about such anyway, just to explain that I hadnt time to explore this in depth in help menus etc etc etc. . I just hoped for a quick fix to assist with cracking on with this.
I think others would also find a massive sea of crosses a mess, just how my luck runs.
