My experience with BlendSrf is the number of control points In the direction from one surface to the other surface) is the minimum number need to satisfy the requested continuity conditions (excluding degenerate situation such as a blend between to coplanar surfaces). For example G2 continuity to both surfaces needs 3 + 3 + 6 control points. Any examples where it is greater than that number?
Also, if you Loft
and MatchSrf
to extracted isocurves on the surface (CurveNearSurface=On) and use History, you can MoveExtractedIsocurve
and slide the blend around to get the shape right. Unfortunately this (History on MatchSrf) only works on one side at a time.
Just checked in v6 and the number of control points matches that of the surfs-to-be-connected.
My claim for blendsurf is based on Rhino5 and before. Afterwards I had barely used it.
Maybe they have improved the command meanwhile.
Going back to the original question I would nominate ‘help’. I use it a lot but suspect from some of the posts on discourse that some people don’t!
I feel stupid right now… after several years I discovered Print Display… I was looking for that option inside Display Modes and maybe it is a good idea to put it also in here? Command is fine but as my defense I must write that It seems to me perfectly reasonable to look for that kind of option under Crv display settings in Display Modes.
So, from now on, I think I will use Print Display on regular basis.
Not sure if I have mentioned this before, but I will write it just in case.
Extracting the surfaces (especially if they are trimmed) and applying “Rebuld edges” before using “Match surface” gives you far cleaner result most of the time.
“RemoveMultiKnot” also helps most in most situations, followed by “Match surface”.
Can you post an example?
One other thing I can add now that it comes to mind - I use subobject selection a lot. In V6, it can be applied to polycurves and polylines to select individual segments within the curve. I now use this regularly when working with polylines, especially the ability to sub-select one or more segments and move them a precise distance via Gumball or simply hit the Delete button to create openings.
I can’t reproduce such scenario now, but it happens quite often in my workflow. And “Rebuild edges” is the only solution that makes the eventual “Blend surface” or “Match surface” simpler.
However, in rare occasions “Rebuild edges” does the reverse effect and here is one example where “Blend surface” gets over-saturated with control points if you apply “Rebuild edges” to the trimmed vertical surface. “Remove multi knots” will make it a bit simpler.
Rebuild edges 1.3dm (123.0 KB)
Thank you for teaching us about ContextMenu. It is very useful.
If you don’t mind, would you tell us about your SemiSmartPopUp Macro and share it with us ?
It sounds great to me but I couldn’t find it in docs-mcneel, mcneel wiki and discourse-mcneel.
Hello - ‘SemiSmartPopUp’ is a scripted tool I made a long time ago to try to pop up context sensitive menus… depending on the current selection. It only partly worked… 8^)
Hello.
I understand.
Thank you for your quick answer.
Absolutely true! Subselection
MarkSurfaceDiscontinuities
, which looks for internal discontinuities of surface.
I’m very grateful to pascal for this great plugin.
The image below is the result when I run
_MarkSurfaceDiscontinuities _Details=Yes _MarkAllFullyMultipleKnots=Yes _KnotColor=255,0,0 _G0Color=0,0,255 _G1Color=255,0,255 _Samples=32
I just discovered Notes. The note also appears in the windows preview panel. It’s very useful if more people are working on the same file and I use it for referencing specific local coordinates to the origin point.
bingo. this is third on my list.
it took me a while to get curve boolean down pat. it’s much easier now it seems.
Looks like that issue have been fixed in Rhino 7. Cool.
I will have to test it with some more challenging drawings where Rhino 6 struggled to do it properly.
