What method to see name of .obj after import?
V5
If I click on the .obj I had imported a year ago, where can I view the file name of the .obj ?
Cheers
Steve
You can’t. Rhino has no idea where that imported object came from. All you can see is if the object itself has a name, which in all likelihood is not related to the original file name.
oh dear, I would say then that when importing an .obj one needs to afterwards ensure the entire path to the file and the file name itself is copied to …
a note attached to the object
or
a text block grouped to the object
or ???
what is best and is there a note command to attach notes to objects and how are these known about as one doesnt want text visible always.
meanwhile if I import the obj again, or what I think was the obj
and searching my .obj’s I should see some contenders,
how best to see if its that one, polycount I presume.
Cheers
Steve
Yes, it is perhaps possible to store the file path as user data on the object. But you would need a special scripted .obj importer that is programmed to do that. Afterwards you could read that info directly in the file via the Attribute User Text panel (not in V5).
Is there a note command that can be used on objects, not just .obj but any object ?
that can be called up if required. ?
Maybe when one clicks an object some indication occurs it has a note attached, then one runs a command to reveal the note ?
I have imported an .obj and clicked details, and compared the polygons and vertices numbers and they match, so I have found the .obj I used.
Now I wish to copy the gile path and file name into a note or something, and attach that.
perhaps otherwise a text block grouped to it and layer turned off.
Cheers
Steve
