two tapering lines represent the unrolled innermost edge of an aluminium arm. The upper portion of this shape however is in reality bent over on a radius of 70mm.
I need to take the two upper lines which I have split from their remainder and roll bend them through 90 degrees, as if in a vice being bashed around the cylinder.
Projecting them downwards (after leaning them forward so their ends were at cylinder top ) onto the cylinder didnt work., they dont depart the uprights as tangent !
roll bend through 90deg.3dm (53.2 KB)
Steve
