What kind of offset should i try?
please help!
i want to offset a 3D curve in inner directions of red arrows and make a surface like an image i attached.
is there any solution?
Offset curve on surface
https://docs.mcneel.com/rhino/5/help/en-us/index.htm#commands/offsetcrvonsrf.htm
Hello- can you post a file with the surface?
thank you for your message.
i tried OffsetCrvOnSrf command. the result is close but not exactly what i want…
i want to offset the curve inside with only XY directions, no Z direction affected.
sorry, it is hard to explain, but i hope you got what i mean.
i have attached a file. i roughly drew 4 inner-directed guide lines and did ‘sweep1’ 4 times and got a closest solution so far like an image i attached.
sorry i deleted my reply so i posted again.
ideally each point on the curve was offset inside on only XYvector, no Z direction. would you suggest other better solution?
offset matter.3dm (339.0 KB)
Hello - it will all work better if the curves are made tangent or G2 where they meet
Use `_GCon to test - the ones in the image a 6 degrees off.
In addition, I would make sure the radius is greater then the offset distance of 5.
Once that is cleaned up, Join the curves and then use RibbonOffset to get a surface.
thank you. it worked. i learned a lot:)
@fabiidesign
topic solved ?
please check pascal s reply as solution, so other visitors of this forum don t need to dig into the topic.
