Hi
V5
select curve, select transform copy, hold shift move the copy hit tab and its constrained to the parallel to plane direction I started to drag it, after clicking to place the first copy that tabbed constraint is lost and my drag line can be at any angle.
How do I get multiple copies at whatever position I choose to retain that initial constrained move ?
Check the command line options in Copy after you have set the initial copy… Notably, you have FromLastPoint, UseLastDistance and UseLastDirection. If you set all 3 to yes, you can make multiple copies in the same direction like an array. I have an alias ‘ddd’ which is
