Want to remove RH5 from win7 64bit to reinstall an earlier SR. without screwing up Rh4 on the same machine.
What is the best way ?
As far as I can tell, uninstalling RH5 shouldn’t affect RH4 in any way.
That said,…
When I was running Rh5 beta and deleted it via add /Remove it affected the licence file in V4 had to re install.
Now have v5 upgrade that I need to go to an earlier SR for a program to run.
Just checking before I do this.
Rhino 5 installs an updated license manager that supports Rhino 4 and older products. Try as I might, I was never able to make the Rhino 5 installer just leave it there during uninstall. The result is that removing Rhino 5 will may cause Rhino 4 to not find a license.
However, you don’t need to uninstall or reinstall Rhino 4 - just installing Rhino 5 again is enough to get Rhino 4 working.
Thank you I will do that
