What is the best way of exporting scheme text in a dxf file?
Hello all,
I use a dxf files for plotting only the text on a pvc sheet. I would like to know if when a dxf file is exported with imperial cam affects the text format and if so what is the best option to export or doesn’t have anything to do?
Thanks
Hello Jose,
DXF does not support camera.
Whatever the number of cameras, their focal lengths, perspective or not, they have no influence on the recorded data.
On the other hand, I advise you to vectorize the texts.
-jmv
Hi Jose -
The different schemes or settings in those schemes won’t influence how text is exported. When this is used for production, you should make sure that the receiving application reads your file as intended. For most control, as @kitjmv also noted, you can explode the text into curves.
