What is the best approach to segment a (curved) surface?
Hi all,
I’m currently working on something a bit the other way around than usual grasshopper projects.
I have a model of a wind turbine blade. The outer surface is divided in multiple untrimmed surfaces. Now I want to segment the blade surfaces into multiple pieces (so that you get beams and plates for housing). The ultimate goal is to be able to extract multiple elements from comparable sizes out of the surface.
Does anybody have an advice on what is the best approach for this?
I thought of constructing a mesh from the blade and then split the mesh into multiple components but I do not have an idea yet whether this is the best approach.
Looking forward to your advice!
