With 6 I have to set each layer to .25. The default is way too light. Is there a way to do this globally?
Thanks
Thanks
The Print Width is a layer assignment so it is initially inherited from the template file you used when you created the file.
In an existing file you can range select the layers (click, hold shift, click) and change the selection all at once with a minimum of clicks.
Can you not do that when you print?
Default lineweight in V5 is “hairline” and I set the global value when I print.
(Don’t have WIP now due to the install issue)
Thanks. Both replies helped.
